Fridge and freezer displaying wrong temp, not cooling
Samsung RF32CG5300SRAA 31.5 Cu. Ft. Mega Capacity Smart French Door Refrigerator
Both the freezer and fridge are going way out of temperature. When unplugged and immediately plugged back in, the control panel inside of the fridge will display the accurate ambient temperatures and both the fridge and freezer will proceed to attempt to cool to their set temperatures.
The control panel then seems to get "stuck" on those temps after a few hours and stops displaying temperature accurately / never fluctuates from the set temperature. The control panel will display the set temps at 34°F and -4°F, whilst a separate thermometer inside reads the fridge as being between 40-45°F and the freezer at 35-40°F.
Coils in the back are clean, compressor fan seems to kick on, and the evaporator fans are not frozen. Didn't see any error codes on the control panel and no blinking lights on the PCB. Seems unlikely that both temperature sensors would be faulty, right? Especially since the panel displays the correct temperature when the fridge is unplugged and plugged back in. What else should I be checking?
