メインコンテンツにスキップ
iFixitのFixHub製品ラインの主要電源およびコントロール・インターフェースであるFixHubポータブル・パワー・ステーションの修理およびトラブルシューティング情報。2024年10月発売。
Has anyone had an issue with the battery erroring out?
Hello everyone,
I purchased the FixHub and it works wonderfully except for one small issue. When powering the iron off, after a while I will receive a battery charging halt error at 98%.
otherwise the iron works fine and discharges and charges as normal. Is this just a visual error, or is there something I should look into? I am on firmware 1.0.5
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
9 件のコメント
I’ve forward your issue to the iFixit product team for a response.
さんによる
@danj, thank you.
@kaioshade, we're looking into it.
さんによる
@krisrodriguez Thank you so much for the swift reply.
For some additional information, I am using an Anker Nano II 65W USB-C charger, with an Apple USB-C 240W cable. I have not tried any other chargers yet.
さんによる
@kaioshade, you're welcome!
Thanks for the extra information. I have a follow-up question. Have you calibrated the battery? It's a button in the web UI. It's somewhat expected to have some variance up front with max charging percentages until this is done.
さんによる
@krisrodriguez
I did not do the calibration when I got the unit (apologies, I didn't think to), but I did it tonight. I'll report back if it does happen again. Thanks for the info!
さんによる
4件以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
Mine has only been used a handful of times, and the battery has been self discharging over a week by more than 10%
I also saw that the health percent for it is already down to 89%
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
@omegatotal, have you tried updating to the latest firmware?
さんによる
I just did through every version, now the battery health is MIA, and replaced with a setting for setting the max battery charge.
Also it appears that it is not respecting the inactivity/timeout that I had previously set to 30 minutes (its stayed on for multiple hours today after a couple of power cycles)
さんによる
I just tried changing it to 29 minutes and back to 30 minutes after it stayed on without being touched for 2 hours. lets see what it does this time.
さんによる
コメントを追加
回答を追加する
Cien さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 23
今までの合計 403
