メインコンテンツにスキップ
Released Late August of 2021 Made By Samsung MSRP: 160$ CAN
20回答 すべてを表示
System is lagging and running slow.
How can I make my phone stop lagging and operating slow?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi @perrybishop
Try starting and using the phone in safe mode and check its performance.
If it is OK then a downloaded app¹ may be the cause of the problem. The trick is to find out which one. You will need to uninstall each downloaded app, one by one, and test the phone in normal mode between each uninstall to see if it works OK or not. When it does then the last downloaded app that was uninstalled was the culprit.
¹ A downloaded app is one that you downloaded and installed on the phone and didn't come preinstalled on the phone.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Perry Bishop さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 14
