So, I've taken apart my Farberware FCP412 coffee pot and found the entire heating coil/element is rusted badly. Can the heating element be replaced or shall I just trash it and buy a new coffee percolator?
@michele1l don't bin it yet :-) Let's see what you got going on there. It should be replaceable. Post some good pictures of all that stuff with your Question. That way we can see what you see. iFixitでの質問に画像を追加する方法
@michele1l yeah, looks a little crunchy :-) I wonder if it still works. Rust in itself should not spell the death of it. Do you have a multimeter? If so set it to Ohms and measure the resistance of the heating coil. If this is a 110V percolator the resistance should be about 12ohms.
It doesn't heat enough to make it "percolate" up the tube, but now it starts to heat up and shuts off. I ordered a replacement thermostat before I actually took it apart to see that the old thermostat is pretty immaculate but heat element is corroded. Yeah, I'm getting a new pot. Appreciate your help tho 👍
oldturkey03 さんによる
@oldturkey03
Thanks, added image
Michele1L さんによる
oldturkey03 さんによる
Thank you for your help!
Michele1L さんによる
