メインコンテンツにスキップ
Repair guides and support for tablets manufactured by Supersonic.
Why is the SD port not working?
i got my SC-1022KB used from my mom, who got it from her college at graduation. it's been collecting dust for a few years, but i cleaned it up and reset it.
I'm trying to move things from my pc to the laptop via Micro SD, but the port won't recognize it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If the SD card port on your SC-1022KB laptop isn’t recognizing your microSD card, here are a few troubleshooting steps you can try:
  1. Check the SD Card Adapter: Since microSD cards require an adapter for standard SD ports, make sure the adapter is functioning properly. Try using a different adapter if you have one to see if the laptop recognizes it.
  2. Verify the Card’s Condition: Test the microSD card in another device to ensure the card itself is working. If it works in another device, the issue is likely with the laptop’s SD card reader.
  3. Update or Reinstall Drivers: The SD card reader may need updated drivers, especially since the laptop is older. Go to Device Manager on the laptop, look for "SD host adapters" or "Disk drives," and try updating the driver. If it doesn’t work, uninstall and then restart your laptop to reinstall it automatically.
  4. Check for Dust or Debris in the Port: Since the laptop has been unused for years, the SD port might have accumulated dust. Use compressed air to carefully clean the port and then try the card again.
  5. Use an External SD Card Reader: If the port still doesn’t work, a USB SD card reader can be a good workaround and usually offers reliable compatibility with most laptops.
If none of these solutions work, the SD card reader may have a hardware fault, in which case an external reader would be the most practical solution.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Theft of Apollo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 51
