Why is it not charging?
why is it not charging?
Have you tried a different known working charger or charger cable to check if the phone starts to charge?
Has the phone been dropped or gotten wet at all?
Use a strong light and a magnifying glass to visually inspect the charge port enclosure for any dust or lint that may be preventing a good electrical connection.
If there is any debris in the port enclosure, do not use a pin or probe to try and get it out as you may damage the pins or cause electrical problems in the phone. Try using a vacuum cleaner to suck it out.
If still no good the phone will have to be opened and inspected and tested as to what the problem may be. Here's a teardown video that may help with the disassembly
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 93
