Minolta Freedom Zoom 140EX Panorama Date not turning on
Hi,
I recently picked up a Minolta camera from an op shop, and put new batteries in (definitely the correct ones, model from the official manual(CR123A)), and it turned on and worked well, but I didn’t use it for about 3 weeks, and then it stopped turning on. When I press the power button, the display turns on for 1 second and then turns off again, although the date display is on. The lens is not opening, even though it is moving forward a tiny bit. The batteries are in the correct orientation, because they only fit one way.
この質問は役に立ちましたか?
4 件のコメント
Hi @voydurwarranty
Try testing both of the batteries' voltage with a meter or try a new battery just to eliminate the possibility that one of the first battery( or batteries) has failed for some reason
jayeff さんによる
Thanks, but I do not have a voltmeter/multimeter on hand. Is there any other way?
Voyd ur Warranty さんによる
@voydurwarranty
Without a meter (do you know anyone who has one that they could lend to you?) you don't know the state of the batteries now i.e. good or depleted for whatever reason so the only other option is to try new batteries.
jayeff さんによる
If the voltage is okay, what should I do?
