メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5もしくは 3.4 GHz Core i7 Processor, ID iMac12,2
Reuse iMac camera on MacBooks
I have already figured out the pinout of the camera and soldered the wires to a USB connector. It works fine, with one caveat. If I connect it to a MacBook running in clamshell mode, the MacBook would not enable it, since it thinks it's a built-in camera, which of course makes sense.
Now, my question is, is there any way around it? I can think of two possible options:
  1. Change the USB descriptor of the camera, which I doubt is possible. But this would be a universal solution.
  2. Change the behavior on the macOS side not to disable the camera when the lid is closed. I did some preliminary search and didn't find any answers.
So I figured I'd ask this community and see if anyone has a good idea. Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Sorry I don’t see a way to do that, the camera’s ID is confusing the OS as it was never intended to run two FaceTime cameras at the same time from the same system.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Deling Ren さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 32
今までの合計 207
