メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Meta Quest 2(旧Oculus Quest 2)は、2020年10月に発売された、Oculus Questの後継モデルです。
Turning on automaticity when charging
Hey there, so my quest 2 is having a issue where whenever it’s plugged in to charge it will power back on, I have tried everything to troubleshoot shoot and think it’s a technical issue was wondering if you ever seen this before or know how to fix it
I have swapped the proximity sensor with a good one to see if that was it bc I thought it could be but nope still same issue
Only other thing I could possibly think is the usb charger port/cable but I’m not a pro when it comes to small device repairs so don’t wanna risk it without more details and testing
Idk how this question works but if needed my email is tntn3rd@gmail.com
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Yes it is fully powered off and no it is not the charger cable
I have two quests and only one has this issue
(It isn’t a user issue)
さんによる
Does it actually fully turn on?
さんによる
コメントを追加
2件の回答
ベストアンサー
After trouble shooting for a while and trying everything from the most basic fixes to complicated ones I was able to fix it
I had to replace the charger/port flex cable to fix the issue and to clarify I don’t mean the charger cable I mean the flex cable inside of the headset it self so I took it apart and replaced it with a new one
Sure this wasn’t a huge issue bc the headset was fully functional but it was an issue nonetheless and I have OCD so I had to fix it for the life of me lol
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Is the oculus fully powered off, or is it in sleep mode?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes it is fully powered off, the issue had to do with the power cable
さんによる
コメントを追加
回答を追加する
TnTN3Rd さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 35
今までの合計 541
