Why my phone sometimes restarting?
Sometimes my phone keep restarting, it loops many times in logo before it back to normal again
You can try while charging to see if it's still the same If not, the damage may be in the battery If you still experience the same problem, it's possible that your storage is full or the internal buttons are problematic, it could also be that the SD memory is damaged I hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 13
