screen is only readable at the top
there is a thick white horizontal line in the middle of the screen. Only top 1/4 of display visible
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sounds like the lcd controller is giving problems. Could be physical damage (blow to top of screen) or age. IMnsHO this is not a DIY repair, you could however replace the LCD screen (comes with a new controller board) rather easily. Once you get the back of the case off the display you can read the LCD part number... you can see the amount of work needed to swap the controller (it's a lot and it's delicate) you know your limitations.
Good Luck,
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
No physical damage. Although, when I plug it into my TV , the screen on
TV is perfect but on laptop, white and black. Only very top
Is visble. How much would a new screen be?
Google says from 70 - 200$ You need to have the part number from
the back of the LCD to get an exact match.
Thank you, very helpful
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 525
