Why si my wifi Bluetooth and hotspot greyed out
wifi and hotspot grey out
You didn’t mention what version of iOS you’re on. Make sure you have no pending software updates under Settings > General > Software Updates. Then try Settings > General > Reset > Reset Network Settings.
このアンサーは役に立ちましたか?
The wifi/BT chip has lost communication with the rest of the motherboard, unless it's a simple power or bad contact issue, nobody can fix it because the chip is paired with the CPU and impossible to replace.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 151
