メインコンテンツにスキップ
The Aspire 3 A315 is a repairable laptop by Acer.
Why my laptop is not turning on and not charging?
My laptop was on and charging then suddenly it stops charging and after a minute it switches off and smoke comes out of the USB ports, then it never switches on again. I unplugged the charger immediately and it was too late as I also came to realize that my charger is bend. I tried to open it so that I can inspect it myself, but it does not show any signs of burns from the inside and I tried smelling it so that I'd find out where the smoke was coming from then I found out that it is from the line of the charging port and the USB ports only. I am looking for a fast response with help. THANK YOU
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Double check the condition of the mainboard and every internal component.
Also, unplug the battery and try the charging cord again. There may be something wrong with the battery module, and not the actual mainboard.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Raymond Maleka さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 27
