メインコンテンツにスキップ
日本国内では2017年7月13日に発売されたNintendo 2DSの後継モデルのハンドヘルドゲームコンソールです。海外では「New Nintendo 2DS XL」として販売されています。
Modded 2ds xl not connecting to wifi
My modded 2ds xl will show the internet at full bars which won’t actually work, then it will go off and grey where it just says enabled. After that it will show the street pass icon.
I have tried deleting the WiFi and reconnecting which didn’t work and my WiFi is set to 2.4ghz.
can anyone point me in the right direction for a solution?
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
5 件のコメント
What method did you use to hack it, and what were you doing before this started?
さんによる
@darthmango i used this website and followed its guide https://3ds.hacks.guide
さんによる
I was also using a forwarder to add games to my home screen before i noticed it happening
さんによる
@george25826 i mean, what method as in which exploit? I'm guessing super-skaterhax? The forwarder probably wouldn't be a factor, but we can come back to that if need be
さんによる
@darthmango yeah where it said boot9strap it had (super-skaterhax) next to it
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hi!
Is your 2DS XL up to date?
When you are trying to connect to it again, does it work?
I would try a factory reset and go all over again. This most of the time will solve the issue.
Replacing the WiFi chip it self is an option, but only if the above didn't solved it.
Please let us know how it goes!
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
An immediate factory reset seems a bit overkill IMO. Probably best to try some simpler troubleshooting first
さんによる
@darthmango yeah, your right! Probably for the best to see if it can be fixed before proceeding to the big step. Sorry!
さんによる
Thanks,
I wouldn't mind giving this a go, as the whole modding process is quite simple, but I would like to be 100% sure this works first.
さんによる
@george25826 A factory reset doesn't remove CFW from your console. If you decide to do one, don't try to reinstall it from scratch. At most, you'll only need to do the restoring-updating & finalizing pages
さんによる
コメントを追加
You said you were using a forwarder, were you trying to connect to wifi in 3DS mode or DS mode? DS mode wifi slots are separate from 3ds slots, and have to be set up under Internet Settings -> Nintendo DS Connections.
If that's not it, the problem's probably with the network itself. To check, we'll need another access point to connect to. If you have an android phone, you can host a hotspot over mobile data and connect to that. Windows also supports hosting access points, though you'll need ethernet for that to be helpful
If things work normally using your hosted AP, there's some sort of problem with your regular wifi network.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
George さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 82
今までの合計 530
