メインコンテンツにスキップ
2004年12月12日に日本で発売されました。北米は2005年3月24日に発売、欧州では2005年9月1日に発売されました。
PSP detects select and analog when not pressed
As the title says, the console detects that the select is being pressed and the analog moves down without being connected. The console only turns on if the select is held down, just like the rest of the buttons only work if the select is held down. It also happens, that if I release the select, the console stays on hold. Sometimes when I press a button and release the select, the button stays pressed. I have replaced the flex with a new one but the problem remains and even if the flex is not connected the console still detects it.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
As I specified in the comment of the other answer, what has partially solved the error and has allowed me to use the buttons without the select has been to clean the motherboard of the embedded dust that was on the back.
Although I can use the console, it still detects that the button is still pressed, it may be because I have only cleaned it without isopropyl alcohol and just gently brushing the board.
I leave the link where I found the answer, in case someone has a similar problem with other buttons, since it does not necessarily have to be in the same buttons.
Lastly to keep in mind, it is likely that if after cleaning with isopropyl alcohol the problem persists, it may be due to a short in the plate. For my part I can't check that as I don't have the tools or the knowledge to see where it may occur.
Specified link
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Hi!
This is a strange issue! I recommend to replace the “start, select button bar with cable”.
This should fix it.
Please try this first, and please let us know how it goes!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I did the replacement, but unfortunately it didn't work. I have read that it could be some dust on the motherboard probably shorting out. By and by I didn't see anything from the front, but from the back it had a little dust accumulated in one particular area. Now the console turns on without pressing select, but when I enter to modify the name it still detects that the button is pressed. Due to testing, I installed the official firmware, so I have to redo a custom firmware installation and run the key tester. I will do an update later.
さんによる
Hi! Alright, didn’t heard about this before! Glad that you were able to fix it :)!! Thanks for sharing the answer with us!!
さんによる
コメントを追加
回答を追加する
hardcode さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 26
今までの合計 436
