メインコンテンツにスキップ
This page provides information and repair guidance for the GE Refrigerator GNE25JGK, a standard, non-compact model introduced in 2016 without a through-the-door dispenser or ice maker. This page covers information for model numbers matching the pattern GNE25JGK****.
How do I stop the noise from my refrgerator?
My refrigerator has always been loud off and on ever since I bought it almost 4 years ago. But, we loaded up the refrigerator and freezer yesterday and it has been running loudly (so much so that you can hear it outdoors) for over 24 hours. I did a compressor reset as described here and that did not help. This is driving me insane. Any help is greatly appreciated.
At times my refrigerator gets extremely loud. It is this make and model: GNE25JGKLFBB
RR318465
I chatted with GE and they told me it should run 80 to 90% of the day but it is very loud. It isn't always this loud. It seems worse in the summer but it is cooling down now and it has been running extremely loud for the past 15 hours.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Check the coils loaded up with dust an debris will force the compressor to work harder which then make it noticeably louder. Also check the temps both sections. You might want to raise it a bit if it’s too cold.
If that doesn’t help you may need a new compressor and/or the refrigerant levels need to be adjusted.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Victoria Pless さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 113
