How to change my power button key
how to change my power button key
この質問は役に立ちましたか?
Hi,
If your power button is physically damaged or worn out then you will need to replace it.
Here’s a link to YouTube video showing how to do this:
https://duckduckgo.com/?q=honor+8+power+...
If you don’t feel confident enough then you can get a repair shop to give you a quote on how much it will cost.
Hope this explains what is required in replacing the power button.
このアンサーは役に立ちましたか?
thank you for that
過去 24時間: 6
過去 7 日: 30
過去 30 日: 167
今までの合計 309
1件のコメント
You need a physically repair or replace, or changing the function of the power button ?
Йорданка Железчева さんによる
