メインコンテンツにスキップ
Retina MacBook 2016からアップデートされたバージョンです。モデル番号はA1534(EMC3099)です。Turbo Boost使用時最大3.6GHzの最大1.4GHz Core i7の高速Kaby Lakeプロセッサ、最大50%高速のSSDを搭載し、最大2倍のメモリをサポートしています。
How do I replace the display gasket on a 12" MacBook?
Hi folks, does anyone have a procedure for replacing a display gasket on a 2017 12" Macbook? I know these old tiny Macbooks are nigh-impossible to repair. The screen gasket on my is deteriorating for whatever reason and I'd like to save this device if I can.
The part in question is this one:
MacBook 12" Retina (Early 2015-2017) Display Gasket
Thanks!
Replace the elastic plastic gasket that fits around the outside edge of the display assembly.の画像
製品
$9.99
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You’ll need to first take the display off following this guide Retina MacBook 2017ディスプレイアセンブリの交換 then you’ll be able to grab the end just behind the hinges (either side) then carefully pull. The rubber has a bit of a rib which is grabbed by the edge of the glass and metal frame. Putting in the replacement is a bit tricky! As you need to start from the middle and make sure you don’t over stretch the rubber. I find a little bit of WD40 sprayed on a paper towel which you rub on the rubber to just barely coat it makes the job easier. It only takes a drop or two! So go easy as you then will have streaks on the display if you go overboard. Once in, I use a cotton pad to wipe the rubber down with isopropyl alcohol (again damp not wet) often using multiple pads to clean the WD40 off. Then a micro cloth with a glass cleaner wiping way from the glass.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you very much for that answer! I really appreciate it. I'll probably get a replacement battery while I'm at if I I'm gong to have to take this thing so far apart to do the gasket. Man, Apple really wasn't designing with repair in mind at ALL back in this time frame.
さんによる
コメントを追加
回答を追加する
Eric Liu さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 15
今までの合計 108
