メインコンテンツにスキップ
2.2 GHz (Turbo Boost up to 3.4 GHz) もしくは2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
Can I run MacBook Pro without a battery?
The replacement battery in my older MacBook Pro (Retina, 15-inch, Mid 2014) is failing. It is not yet overheating or swelling. I've researched the replacement process here and concluded that it is more than I care to undertake. I suspect that the replacement battery now in the device was inferior and the guy who replaced it is now out-of-business. I am nowhere near an Apple Store. I now use the machine largely for internet browsing and viewing documents. I have an iMac for more demanding work.
I am, therefor, wondering it would be possible to remove the battery before it creates problems and run the machine via AC power?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Not really, if you take the battery out the systems SMC logic will go into CPU Safe Mode lowering the CPU’s clocking and pump up the fans.
I think you’re worrying a bit too much, if you take it out putting a new one in isn’t much more. Follow the guide here MacBook Pro 15'' Retina Display Mid 2014のバッテリーの交換 and for $85 USD you can get a good replacement MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery with the tools which are needed! If you have what you need $77 for the battery alone.
I’m sure you can do it, more so as you stated the system is on its second battery, I often find the replacement are much easier to replace than the original as Apple really glues them in.
Replace a 8700 mAh battery compatible with MacBook Pro 15" Retina (Late 2013/Mid 2014). 98 Watt Hours (Wh), 11.26 Volts (V).の画像
製品
$89.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jack さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 24
今までの合計 264
