メインコンテンツにスキップ
The DJI Mini 2 SE, The base model version of the previous Mini 2. With 2.7K video recording, it’s a great drone for beginners.
Gimbal Vibration Mount Replacement
Does anyone know how to replace the gimbal vibration mount? There are like no guides on how to disassemble the actual gimbal
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi,
Not familiar with drones but did find this teardown for you.
https://www.fictiv.com/articles/dji-mini...
Also a selection of videos describing several components on mini 2 that may be similar to the mini 2 se.
https://forum.dji.com/thread-293492-1-1....
This link has individual YouTube videos for each of the component parts separately.
Hope this helps
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
It’s more the actual gimbal assembling need to disassemble as the top mount had snapped completely and it didn’t get the refresh plan like an idiot. I’m used to doing smartphone repairs and it seems like a simple fix however there are no guides on how to disassemble it
さんによる
Hi, this is the closest I could find for gimbal disassembly.
https://m.youtube.com/watch?v=O8ScD29nkN...
It covers disassembly of the gimbal for wire replacement and hopefully it’s enough to get you in a position to either replace the housing or be able to glue it with gorilla glue.
さんによる
Helpful Harry, yes you are correct, Mini 2 and Mini 2 SE are pretty nuch the same.
さんによる
コメントを追加
回答を追加する
DomTerra さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 29
今までの合計 140
