メインコンテンツにスキップ
GSM iPad 2は16、32、64GBの容量オプションがあり、Dual Core A5プロセッサが搭載されています。モデル番号はA1396。修理作業は複雑で、ヒート(熱)を当ててこじ開ける作業が必須です。
Ipad not switching on after attempting digitizer repair.
Hey guys,
A few days ago my gf stepped on my ipad and cracked the screen.
The digitizer itself was still working but the glass was just cracked.
I ordered a new digitizer off ebay and today attempted to do the repair myself following Andrew Bookholt's tutorial here on iFixit ( iPad 2 Wi-Fi EMC 2415のフロントパネルアセンブリの交換 )
Unfortunately after the repair my Ipad is not switching on and im not sure if i might have somehow damaged something during the process.
Any help would be greatly appreciated!
Thank you in advance,
Bijmin
After scouring how to videos it would seem I ripped the power flex cable on the top right of the ipad.
I will order a new cable and hopefully thats all that was damaged... or I might just end up with a new Ipad at the end of the week haha.
I'll leave this post up in case anyone else has any similar issues.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
5件の回答
ベストアンサー
try to power up with data cable . with cable it will sure power up . if it power up then just change the power cable.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
It boots up and responds perfectly! Volume buttons are functioning but its just the power button that isn't responding. Thank's for your help Simran! At least I can still use my Ipad now while I wait for my new cable to arrive :)
さんによる
thnx for accepting
さんによる
コメントを追加
i have same problem , how change the power cable.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
HI I have a solution for you
Just do a HARD RESET (Home+On/off) together for few seconds and viola!! its on, the reason lies in the discharging thing, if you replace your lcd without powering off your device, most likely this will happen, so try hard reset will do!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I agree with the post above. If your LCD is dim then it is caused by disassembling the device without power it off. If you can't do a hard reset it is most likely due to the power flex being severed. This is common. Also 1 tip if the LCD doesn't light up take it to a microsoldering guy and he can fix it for you. This has happened to me before and they were able to fix it at a computer repair shop. Good luck.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
irepairseattle, please refrain from placing your URL or links to your own website in the answer. This can be construed as spamming and thus violates ifixit policies.
さんによる
コメントを追加
I have a same problem. I changed power cable, but problem is still there. I'm trying to do hard reset, but Ipad blinks Apple logo only during charging from the wall.
So I can't turn it on and connect to PC in order to make a Hard reser.
Please help!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
bijmin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 9,290
