メインコンテンツにスキップ
トヨタ自動車の車両とトラックの修理ガイドとサポート。
985回答 すべてを表示
Why wont my 2003 Toyota Camry start?
I have a 2003 Toyota Camry 4 door sedan. All of the lights come on but it wont turn over or start at all. Even when we tried to jump it. The radio and 6 disc CD player haven't worked in a while. I don't know why but a friend of mine was under my hood trying to figure out why my radio and CD player didn't work over the weekend. After that my car wanted to die when I would come to a stop. Now it's progressed to not wanting to start at all. All the lights come on but nothing happens when I turn the key.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Jen, check the wiring. Start of with the battery. Do you lights dim when you try to start your Camry? Do you hear your starter click? Clean the battery cables and check them for corrosion? Check the starter wires as well as the main fuse block.If your Camry had no issues before, either the battery got drained, or cables got disconnected/broken in the CD repair attempt.
このアンサーは役に立ちましたか?
スコア 6
1件のコメント:
My car is doing the same thing except I don’t have a CD player I have Bluetooth
さんによる
コメントを追加
I would say Oldturkey03 is on the right track of trouble shooting. The fact that your car wanted to die when it came to a stop, then had trouble starting leads me to believe it might be alternator related. Your battery is not powering the car when the engine is running. If you don't have any luck following Oldturkey's suggestions, next time you attempt to jump it, try letting the jumper cables charge the battery for a bit before trying the starter.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
Jen さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 37
今までの合計 11,809
