メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Oppo A37 A37fw 16GB comes with 2GB of RAM. The Oppo A37 runs Android 5.1 and is powered by a 2630 mAh non-removable (as told by Oppo ;-) battery. First released in April,2017.
My display is not working
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント:
Hi , what happened to it? Does the phone do anything.
さんによる
My mobile display is not working
さんによる
Mobile display is not working
さんによる
Is it black screen nothing or can you hear and feel sounds and vibration when you connect to a laptop or turn off and on. The point being is the phone alive or not? If phone is showing lights/ sound or vibration it’s screen related .
さんによる
Screen related ..OR you did work with battery connected in which case try removing and reseating the battery connector.
さんによる
コメントを追加
1 件の回答
@swetagiri @dhananjayp58320 if this is isolated to your display, change it first. Once you have a new display and it still does not work, you can always check further, but until you have changed it, everything else will only be a guess. A new display will give you a known-well starting point for further troubleshooting.
Since iFixit does not yet have a specific guide for this, use something like this video Replacement LCD's are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sweta Giri さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 24
今までの合計 126
