メインコンテンツにスキップ
HPによるフォトインクジェットプリンターモデルの修理ガイドならびにサポート情報。
How do you release ink carriage stuck on the right hand
How do you free the printing carriage stuck on the right on a HP Photosmart 8250 printer
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
@jameshogg15084 let's see if our printer Guru @nick has an answer for you.
さんによる
@oldturkey03 Got it, not a great potential outcome but I've pointed out a few common areas to check.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
These were significantly different for HP compared to the integrated head designs like the tri-color cart and 564/920 printheads. As such, the head will require significant disassembly to access. To access the printhead for unjamming, you'll need to remove the printer's top cover and disconnect the ink lines to access the head on the 02 printers... It's a bit of a burden to service these, much like the modern factory bulk ink tank inkjets we have now (the only difference is the ink capacity, which shares the same poor serviceability characteristics).
Once you get the top off, look where the printhead service station rests (having photos of the service station will help us all find out where the gears you need to reverse are). HP usually has an open-gear design, which means you can probably reverse the gears by hand if need be. That said, if you can turn it on, I recommend this over the force method, as it is safer and less likely to damage the printer. Once you get the head unlocked, unplug the printer, and then you can investigate the source of it.
Given a preliminary educated guess, I would guess one of 4 faults (this is sorted by order):
  • The service station gearbox is wearing out (most likely)
  • You may need to check the condition of the grease of the metal bar the printhead glides across, and clean it with IPA and re-grease the bar (second most likely)
  • Ink backlog is clogging the gears (less likely)
  • Bad service station motor (unlikely, but it happens)
While I do not have a 02 printer to show this on, this video of a printhead cleaning may point to another potential cause: There are 2 lifters on the printhead, and one seems to be prone to breaking as these printers age due to HP cost reducing the mechanism on these 02 ink tank printers to get the cost down, as the head layout is similar to the HP wide format machines such as the Designjet and HP Latex printers.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
James Hogg さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 110
