メインコンテンツにスキップ
The Samsung Galaxy A52s is Samsung's upgraded variation of the Galaxy A52.
20回答 すべてを表示
How to replace a broken vibration motor?
Some time ago I noticed the vibrations of the phone being kind of strange like the vibration motor was loose inside the phone or something. The vibrations rattled even in my hands. Now, however, the vibration is gone entirely. Even when I test the vibrations in the diagnostics panel, I get nothing.
I live in a region where Samsung certified repair shops are in limited numbers. There's only one in my city and they told me that they are not sure if it can be fixed. Is there something I can do to fix it or do I just have to live with it?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
There’s an ideal iFixit guide for you to follow here:
Samsung Galaxy A52s Screen replacement
It’s a screen replacement guide which includes steps to remove vibration motor, but you’ll only need to go as far as removing the top mainboard.
The vibration motor isn’t mentioned until after the battery is removed - if you watch the battery being removed he then tells you about the vibration motor at the upper end where the mainboard was removed.
Hope this helps
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Daedalus308 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 19
過去 30 日: 60
今までの合計 329
