メインコンテンツにスキップ
Repair information for the SteelSeries Arctis Pro wireless headphones. Released in March of 2018. Model number: 61743.
How repairable is the hardware microphone mute button?
The mute button for the microphone seems to have a loose connection, as when I turn the mute on or off, it beeps and randomly activates/ deactivates the hardware mute until I tap the left earpiece. I'd rather avoid replacing the whole headset due to the price.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Somone said they used wd-40 contact electric spray on it and that solved it, others say you keep pressing and unpressimg the mute button, if you still have warranty contact manufacturer.
If you're a tinkerer you can disassemble the headset and clean the mute button from the inside, if that doesn't solve it then I would put a small solder point on its tip from the inside and keep it unmuted all the time and not play with it, maybe use software matting instead after.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Corey Sutlief さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 68
過去 30 日: 327
今までの合計 1,499
