メインコンテンツにスキップ
モデル番号はA1236で4もしくは8GB容量
Removing scratches from the back?
I got a iPod nano for 10$ and it does work, but it is scratched up like mad on the back
Is there anything i can try to to remove some, if not all of the scratches?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Nick, what I do with the older back plates is to use some buffing compound and a buffing wheel. This usually removes most scratches Depending on how deep they are). Your Nano is a bit small and tough to hang on to, so be careful if you use a wheel. Otherwise you will have to buff it by hand. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Most of them are the light ones that are pretty typical on shiny back iPods, a few lighrt scratches
さんによる
Yes, they should buff out.
さんによる
i'll have to try it and get a case to avoid this again, although it's commonplace, i do want to keep it minimal
さんによる
Thanks for accepting my answer. Yes, a case would be good, since they do get banged up quite a bit. Good Luck.
さんによる
this one has dings on the faceplate from being dropped, and scratches too, pretty clear old owner, who was a friend never used a case
さんによる
コメントを追加
回答を追加する
Nick さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 8
今までの合計 1,646
