メインコンテンツにスキップ
Glue panel back together?
So I had this monitor for some time now, and the lcd panel started detaching from the backlight. Any suggestions on what type of double sided tape or glue I could use?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
@alenortiz don't use glue since it will only make a mess. I would use a tape adhesive and tape it over the screen/case along the seam, to keep things safe. Easier to remove and a whole lot less mess. I prefer a good nylon tape or even some decent Gaffers tape. Should be available at any good hardware store or even a fabric store.
What makes me wonder is, why is it separating....
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Nylon tape sounds like a good option, thanks a lot, I will give it a try… and I don’t wanna say it started separating because of built quality, but maybe the environment, I had to install a dehumidifier because of how muggy it gets.
さんによる
@alenortiz yep, that definitely does do it. Humidity and tempos are a killer of our electronics, Stay safe !
さんによる
コメントを追加
回答を追加する
Alen Ortiz さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 29
今までの合計 275
