メインコンテンツにスキップ
2020年4月に発表、発売された第二世代iPhone SEの修理と分解情報です。
20回答 すべてを表示
Why is my phone overheating
My phone is always so hot but the shop repair person say theres nothing wrong
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント:
Hi @xcotton_candyx
What is the make and model number of the phone?
Does the phone always have access to the internet? Check if there's a data saver setting that allows you to control whether the phone connects to the internet or not. It could be that apps are using the internet in the background unbeknownst to you therefore the phone is working harder than normal and gets warm. It should never get that hot that you can barely hold it.
さんによる
Hi! I’m happy to help!
A phone can overheat for a lot of reasons. For example, using resource-heavy apps, like streaming services or games, being in direct sunlight, or from simply charging your device.
I do have a few questions so that I am able to help you:
What kind of phone are you using?
What is being done when your device overheats?
Do you get a temperature warning on your device when it overheats?
さんによる
@jayeff urm iphone SE 2020 and yes there internet
さんによる
@chance35043 dont hv warning only got alot of times when they say charging on hold and wait till go normal temp
さんによる
コメントを追加
1 件の回答
Oh ok, so does the overheating mainly happen when you are charging the device, or with normal use?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
normal use and when charging
さんによる
Oh ok! Thank you! It is normal for an iPhone to heat up when charging and sometimes during normal use.
Does your phone get so hot to the point that it is uncomfortable to hold?
さんによる
コメントを追加
回答を追加する
Celine さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 60
