Mengapa sound atas hp saya tidak bersuara
Speaker atas hp tidak ada suara
Translation Indonesian - English
Why is the sound on my phone not working?
The speaker on the phone has no sound.
@trionoyono first make sure that all of your phone settings are properly set for the internal speaker. It's possible that a third-party app is causing the issue so you want to start your phone in Safe mode. In safe mode third part apps are not run.
Start Safe mode while your phone is turned off
If your speaker works in safe mode, you know it is a third party app that is causing this issue. Time to uninstall those apps one after the other until you know which one works.
If safe mode does not make a difference you can try and see if you can get your phone into diagnostic mode.
Dial *#0*# to get into the diagnostic mode. Here you should see the speaker test. See if your phone passes the test. If it does not, you definitely know it is your actual speaker.
Replace the speaker next. Since iFixit does not yet have a guide for this, use the one from here It was written in Spanish. Use a browser that will translate it for you, if needed. Replacement speakers are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@trionoyono pertama-tama pastikan semua pengaturan telepon Anda telah diatur dengan benar untuk speaker internal. Mungkin saja aplikasi pihak ketiga yang menyebabkan masalah tersebut, jadi Anda ingin memulai telepon Anda dalam mode Aman. Dalam mode aman, aplikasi pihak ketiga tidak dijalankan.
Mulai mode Aman saat telepon Anda dimatikan
Jika speaker Anda berfungsi dalam mode aman, Anda tahu bahwa aplikasi pihak ketigalah yang menyebabkan masalah ini. Saatnya menghapus aplikasi tersebut satu per satu hingga Anda tahu mana yang berfungsi.
Jika mode aman tidak membuat perbedaan, Anda dapat mencoba dan melihat apakah Anda dapat memasukkan ponsel Anda ke mode diagnostik.
Tekan #0# untuk masuk ke mode diagnostik. Di sini Anda akan melihat uji speaker. Lihat apakah ponsel Anda lulus uji. Jika tidak, Anda pasti tahu bahwa itu adalah speaker Anda yang sebenarnya.
Ganti speaker berikutnya. Karena iFixit belum memiliki panduan untuk ini, gunakan panduan dari sini Panduan itu ditulis dalam bahasa Spanyol. Gunakan peramban yang akan menerjemahkannya untuk Anda, jika perlu. Speaker pengganti tersedia di banyak toko daring.
Saat Anda mengerjakan ponsel, ambil banyak gambar. Setelah selesai, ambil gambar tersebut dan buat panduan untuk iFixit. Itu akan membantu orang berikutnya yang memiliki perangkat dengan masalah yang sama seperti Anda. Membuat panduan ini mudah dan menyenangkan. https://ifixit.com/Guide/new Komunitas iFixit akan menghargai ini.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 20
