メインコンテンツにスキップ
The Samsung Galaxy A10s is an Android smartphone developed by Samsung Electronics, and was released in March of 2019.
Mengapa suara speaker hp saya menjadi pecah?
Suara pecah tidak nyaman untuk didengarkan, suara yg kasar
Translation Indonesian - English
Why does my cellphone speaker sound cracked?
Broken sound is uncomfortable to listen to, rough sound
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@chelaw double check your phones audio settings.
See if you can access the Samsung Hardware Diagnostic by dialing *#0*# There you should see the speaker test. Run that and if your speaker still sounds bad, it is time to replace the speaker.
Since iFixit does not yet have a specific guide for that, use the one from here It is for the A10 but works the same way as your model. It was written in Spanish so use a browser that does the translation for you. Replacement speakers are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@chelaw periksa kembali pengaturan audio ponsel Anda.
Lihat apakah Anda dapat mengakses Samsung Hardware Diagnostic dengan menekan #0# Di sana Anda akan melihat tes speaker. Jalankan itu dan jika speaker Anda masih terdengar buruk, sekarang saatnya mengganti speaker.
Karena iFixit belum memiliki panduan khusus untuk itu, gunakan panduan dari sini Ini untuk A10 tetapi cara kerjanya sama seperti model Anda. Itu ditulis dalam bahasa Spanyol jadi gunakan browser yang menerjemahkannya untuk Anda. Speaker pengganti sudah tersedia di banyak toko online.
Saat Anda menggunakan ponsel, ambil banyak gambar. Setelah Anda selesai melakukannya, ambil gambar itu dan buat panduan untuk iFixit. Itu akan membantu orang berikutnya yang memiliki perangkat dengan masalah yang sama seperti Anda. Sangat mudah dan menyenangkan untuk membuat panduan ini. https://ifixit.com/Guide/new Komunitas iFixit akan menghargai ini.
Perbaikan adalah Perang Melawan Entropi!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Chelaw さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 46
