メインコンテンツにスキップ
Replaced DC-I. it worked for a couple days. Then Died. Why?
I replaced my DC-I board. It worked for a couple days and seems to have died. I'm wondering if my after market,(not from you), battery could have killed it, or if you have any ideas What might have. I'm back to only getting an orange/yellow light on the power chord.
Could it have been a faulty, (from You) DC-I board?
I hope I'm calling it the right thing it's the board that the power plugs into.
Oh and by the way the inside of my mac was a little different than yours on the how to guide. I'll send you a pick if it will help, but right now it's in one piece and I thought I'd leave it that way till I have a plan...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
6 件のコメント
What part number did you order and what are the last three figures of your serial number?
さんによる
I ordered part #IF 154-073-1
G4 Aluminum 15" 1.5/1.67 GHz DC & Sound Card
the last three figures of my serial # are SB7
さんによる
Hi Mayer and thanks for jumping in. I just read on another Post where it was a good Idea to unplug and leave that Bat out for 24 hrs and try it again. Since I'd had mine that way for days I tried reintroducing the battery and connecting the charger and Now (Amazingly) it's on.
With that added info can you tell me what's going on with this aging gem.
さんによる
Thank you Mayer. I would love to if I could get it to boot up again. I'm just getting the orange light on the chord and no charge. I had some luck before disconnecting the disc drive previously so I'll try that again. Thank you! I'll let you know. JohnZ
さんによる
Apple PowerBook G4 1.67 15" (Al) Specs
Identifiers: 15-Inch 1.67/1.5 - M9677LL/A - PowerBook5,6 - A1106 - 2029
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
Sorry, I missed getting back to you. I've had varying luck with aftermarket batteries. Some have only lasted four cycles. Download and run Coconut battery on both the old and the new batteries. Use this older version that will run on your machine: http://www.coconut-flavour.com/coconutba...
Let us know your results. FYI - most of us that answer questions do not work for iFixit, we're just volunteers trying to help others.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Frankly, I'd return the part
さんによる
Use a multimeter and test the output of your AC adapter. What are the test lights on your battery telling you?
さんによる
コメントを追加
回答を追加する
johnzip さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 533
