How to fix square button?
The square button when pressed is stuck and feels awkward. Feels like a controller with a sticky button. I tried alcohol and blowing it. need Help!
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You can find a repair part to fix the PS Vita square,cross,round, triangle, start or select button here :
http://www.consolereparatie.eu/contents/...
Verry easy to fix it yourself, you can use the PS Vita teardown guide found on here :
このアンサーは役に立ちましたか?
i can only suggest calling sony it is still in warrenty and this issue will be covered because its not your fault. you can take it apart but there arent many spare parts knocking around so i would just call them they should replace it
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 4,809
2 件のコメント
has anything been spilt down it or is it the mechanics of the button?
daniel robinson さんによる
@ daniel robinson It is the mechanics of the button
joseph floyd さんによる
