メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2021年2月に発売されたSamsungのAndroidスマートフォン、Galaxy A32 5Gの修理および分解情報です。
Why is my phone stuck in an eternal loop of restarting?
My phone was lagging so decided to try restarting my phone, but I pushed the restart button and nothing happened. I pushed it a few more times then pushed the power off button. Immediately the phone restarted and when it finished, it restarted again. It restarted over and over again for about 2-3 hours before it stopped (probably because it ran out of battery) and holding the power button would just make the screen slowly flash black. when I plugged it in, it turned on again but it just starts the eternal loop of restarting again.
also every time it restarts it flashes some text that I can't quite make out.
画像
this is the sharpest I could get it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hey hi Benjamin, your stuck on a boot loop. Go to the given link, read the solution and try to do it: SOLVED: My phone is fully charged but not turning on it is only showing up it' - Xiaomi Mi 2 - iFixit
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I tried doing the soft reset and entering recovery mode using instructions specifically for the samsung, but recovery mode would not work and the soft reset seemed to work at first, but then the text flashed again and it restarted.
さんによる
@benjamin7425 can you please try to make the image more clear so that it is understandable for me and then I can further investigate on the problem. Also sorry for the late reply Benjamin!! Sincere apologies for the late reply. Please its a kind request to get a more clear image of the text that is getting flashed after every restart or so.
さんによる
コメントを追加
回答を追加する
Benjamin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 33
今までの合計 640
