メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
20回答 すべてを表示
Samsung Galaxy S III is On But Screen is Blank
Hello,
I am unaware of this phone's history since I got it from auction. This phone turns on and makes sounds when I press the volume button, but the screen is not even functioning at all.
What could be the cause of the issue? Can it be resolved?
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@tanveerzubair all of this "phone turns on and makes sounds when I press the volume button" would lead me to replace the display. A failed screen will exhibit all of these symptoms. Anyhow, replace he display and then re-evaluate Samsung Galaxy S III LCD Display/Front Glass Replacement - iFixit Repair Guide
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
How would all the pixels fail on an AMOLED screen? I think the actual display is fine. Something else could be wrong. Anything else I could try before thinking about buying a screen as a last resort?
さんによる
@tanveerzubair You seem to have some misconceptions about how screens fail. Yes, you can have individual pixels fail, but it's just as common to see screens with no display at all. There are delicate connections between the flex cable and the glass the circuitry is printed on that are all too easy to dislodge as a result of a blow or a fall, and once that happens there's no fixing it; all you can do is replace the screen.
さんによる
@dadibrokeit Alright. I may just use it as a parts phone. Screen replacements are more expensive than the value of the phone itself anyway.
さんによる
コメントを追加
回答を追加する
EverythingAwesomeTech さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 9
過去 30 日: 9
今までの合計 44
