メインコンテンツにスキップ
The Galaxy A12 is a low-end slate Android smartphone released by Samsung in November 2020 as a successor to the Samsung Galaxy A11. Identifiable by model number SM-A125 (followed by version/carrier-specific character.
20回答 すべてを表示
Fixing the black line on the phone
  1. How to fix my black line on the the screen
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@ragalugard that will depend. It is possible that this is a bad LCD or that this is related to a bad flex cable, a bad connector or a bad video circuitry. I would suggest you
a. post an image of what your screen shows.
b. consider replacing the display assembly and see if that fixes it.
If it does not you know that the issue will be on the circuit board and will require some good tools and skills to fix that. Oh yes, you will also need the schematic and component layout for your circuit board.
To work on your phone, you can use this guide Samsung Galaxy A12 Disassembly - iFixit Repair Guide or you could refer to a video like this one Replacement LCD's are readily available. Those come with and without the midframe. I would suggest that you get one with the frame already installed. This will make the task a lot easier.
Let us know what happens when you replace the screen.
Adding images to an existing question - iFixit Repair Guide
iFixitの画像
ガイド
iFixitでの質問に画像を追加する方法
難易度:
とても簡単
2 - 5 minutes
Samsung Galaxy A12の画像
ガイド
難易度:
簡単
10 - 25 minutes
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Raga Lugard さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 13
