Do Quest Pro controllers use the same joystick part as Quest 2?
Hi, I hope someone who has experience disassembling or repairing Quest Pro and Quest 2 / 3 controllers can answer this.
I've heard that Quest 2 and 3 controllers use an identical part for their analogue sticks, but can't find any info on QPro controllers.
This is important because Quest 2 replacement sticks are currently available from Amazon and elsewhere, but there's nothing labeled for Q3 and QPro as far as I know.
Thanks
Edit: Replacements labeled for Q3 are now available.
I also found this reddit thread:
https://www.reddit.com/r/oculus/comments...
"Posting a year later for others looking for confirmation.
The quest 2 thumbstick component is compatible with the pro touch controller, go ahead and replace with quest 2 part.
However, the capacitive spring that is inside of the thumbsticks are not compatible - take care not to deform or stretch the pro controller spring when disassembling the controller to replace the stick assembly.
Good luck, its a complicated teardown."
この質問は役に立ちましたか?
