My phone no longer charging and no usb c device is working with it
I can only charge my phone using the wireless charging. What can i do to fix it? i tried cleaning the port
@cliftonsammut sounds like a bad charging board. In the case of your phone the charging port is soldered to the daughter (sub board), I would suggest replacing that board. Use this guide OnePlus 9 5G Daughterboard Replacement for that. Replacement boards are readily available at many online stores.
Of course, there is always a possibility that this is caused by a failed flex cable from the main board to the daughterboard. Make sure it does not have any tears and it is properly connected etc.
このアンサーは役に立ちましたか?
過去 24時間: 5
過去 7 日: 5
過去 30 日: 5
今までの合計 5
