メインコンテンツにスキップ
モデル番号はA1373/2GB容量
31回答 すべてを表示
締切られた回答
which battery to order?
I ordered a Shuffle 4th gen batter from ebay: 3.7v 0.27whr. it is too big and the leads are different.
the 5th gen battery on ebay looks similar to mine has correct leads, and almost identical whr.
http://www.ebay.ca/itm/Repair-Replacemen...
anyone know which battery to order and why the mismatch?
(my device is the square with the circular button pad on the front).
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
ken, check on here. Step 4 shows the battery, and it says " 616-0548 (corrected due to poor eyesight;-)" that is the one I would get:-) Careful with the pictures on ebay. A lot of those are just a representation of what they are trying to sell. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you for the quick reply.
In case another goes looking for the modle number the correct number from the photo is:
"616-0548"
...(i read the last digit as a "3" as well the first time:)
ordered it on ebay. the seller labels it as a 5th gen. Amazon also labels it as a 5th gen.
Will update if it fits. wish me luck
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 2,131
