メインコンテンツにスキップ
任天堂の最初の3DSモデルは日本で2014年10月に発売され、北米では2015年9月に発売されました。Newニンテンドー3DSは改良された3D機能、Cスティックと新ZLボタン、ZRボタンが特長です。
SELECT button is triggered by pushing down on the lower baseplate
I just recently got out my 3DS that I haven't used in years and decided to mod it. After using it for a while I noticed that during gameplay the pause menu in some games would come up randomly.
During some troubleshooting I found out that pressing down on any part of the lower baseplate of the 3DS causes the SELECT button to be triggered and the closer you get to the right side of the 3DS (where the SELECT button is) the easier it is to unintentionally trigger it. Also, the physical button is not moving just to inform you.
I originally intended to disassemble the 3DS to just clean it but now it seems I might have to do some investigating as well.
Posting this here as a precaution to see if anyone know what is causing this before opening the 3DS up myself.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Ronan!
Maybe there is some dust there! Best thing to is to disassemble it and clean it there.
If cleaning isn't working, then it's probably for the best to replace the part.
Luckily those buttons are located at the power board! Replacing the power board is easy.
Guide: Nintendo 3DS 2015 C-スティックの交換
Good luck with the repair and please let us know how it goes!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Ronan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 120
