Why wont my printer copy or print
I can not get my Epson printer to print or copy any suggestions?
Check the ink levels first. Epson designs its printers to shut down at the printer level completely when it's out of one cartridge. Some of them let you run in black-only mode when you run out of color ink on a computer. If your printer is on this list, you might have a way to use it on a computer, but no other modes will work. If not, then you'll need to replace the empty cartridge. That said if I check the US support pages, yours should support it.
If the carts aren't low, then we need more details, but 8 out of 10 times, these printers shut down due to one cartridge reading empty.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 36
今までの合計 36
