Machine draining but not all the way
Maytag top load washer. No error codes, no strange noises, etc. water drains but the clothes are still too wet for the dryer. Run a drain and spin and that does the trick. No hose blockages, took the pump off and no blockage at the pump.
Does a partial drain indicate the pump needs to be replaced?
Hi @buckgerard
What is the complete model number of your washer?
There are 5 different variants of the model i.e. MVWB765FW0 - MVWB765FW4 and they are not all wired exactly the same or use the exact same parts.
jayeff さんによる
The model # is MVW6200KW2. Thanks
buckgerard さんによる
