メインコンテンツにスキップ
バッテリーのアップグレードやディスプレイの修理を含むSPS Goの完全修理マニュアルです。
majoir problems with my psp go
the firsst problem is the right side of my psp go is disconnected from the main body and everytime it moved it would just shut off, my next problem is well unclear too me casue thee way i remember it was that that my pspgo would not charge but also it will not turn i even used my friends charger still nothing happened so i guess the charging station is broke.or my psps just wont turn on can some one help cause i have a lot of games on my pspgo that i cant play but would like too
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
Braylon Foreman, the first thing I would try to make sure off is that your battery is working. There might be a possibility that it is not holding a charge. The other thing you can try and do is to check the fuses on your GO to make sure they are working. Also, check the logic board for any damage, debris, corrosion. You can clean it with isopropyl alcohol. Hope this helps to get you started. Good Luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
go to sitting check if corging thing is on
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Braylon Foreman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,666
