How to change screen to my laptop?
screen change
Hi @itiplayz92
Here's the maintenance and service guide for the laptop.
Go to p.50 to view the procedure to remove/replace the display assembly. See Step.5 on p.51 for how to replace the LCD panel.
At the top of p.50 you will find the HP spare part numbers for the 2 LCD panels that can be used in the laptop.
Search online for the part number only of the LCD panel applicable to your particular laptop version, to find suppliers that suit you best. Usually the part number is located somewhere on the back of the LCD panel itself, if you wish to verify that you're getting the correct one.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 18
