メインコンテンツにスキップ
Appleの2016年ラップトップラインアップの最新モデルは、プロフェッショナルユーザーを対象としています。 15インチ、2880 x 1800 Retinaディスプレイ、クアッドコアIntel Core i7、256 GB / 512 GB / 1 TB / 2TBストレージオプション、16 GB RAM、およびTouch Barを搭載したキーボードです。
MBP 2016 running Windows 10 (bootcamp) shuts off in sleep or hibernate
I have a Macbook Pro 2016 15-inch touchbar that is running a fresh install of Windows 10 via bootcamp with all drivers installed via the bootcamp software. Everything works great, except the fact that when the computer is asleep or in hibernation for a while, it seems to crash and shut off, and I see when turning it back on that all my programs/tabs are closed, and the OS reports that Windows had not been properly shut down. I have searched all over online for any records of anyone else having this issue and I have come up blank. Fast-startup is disabled, and the funny thing is that everything is fine when I wake the computer up within a short period of time after sleep or hibernate, but after leaving it for maybe 15 minutes or more the problem can arise; however it seems to be inconsistent, and hibernate seems to be a bit more reliable. Any help would be appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Somethings can be simple to fix, and some things like this can be caused by many possibilities,
so lets try to narrow it down some, 1st off, did you check all battery and energy saving settings?
2 - Is this happening in a mac or windows environment or both?
3 - Can you provide a complete list of software installed on the system that is having this issue?
4 -Is anything external connected to the laptop at the time of "sleeping & waking up"?
5 - Did this start to happen only after you installed windows 10?
6 - Search "Macbook crashes in hibernation sleep" if nothing above helped.
Hope one of the above can solve it :)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
1 - yes that is all fine
2 - only windows
3 - there is no running software, it is a clean install
4 - it happens with nothing plugged in
5 - it only happens in windows
6 - i have searched all over like that but found nothing helpful :(
さんによる
コメントを追加
回答を追加する
Armen Orbelyan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 65
