My PS5 WiFi Connection Issue
How can I get the PS5 to connect to WiFi again? It will only connect to the internet if it is plugged in using an Ethernet Cable.
Hi Angelina!
First things first, is the PS5 up to date? Otherwise please update it with the network cable plugged in.
Can it find any wifi network? If not, then check the antennes. In the worst case scenario, you need to replace the wifi chip Sony J20H100.
Unfortunately, it’s soldered on the motherboard. So to replace it, it requires soldering skills…
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 18
今までの合計 31
