メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair guides and support for your Samsung TV.
Main Board vs Panel - Backlight Boot Loop
Model: UN65KU650DF
TV Symptoms:
Two thin vertical lines appeared in the middle of the screen a few weeks ago. I ignored as I was traveling. 10 days later and the screen is faded and bleached and the picture is totally washed out. TV still works.
Now the picture is completely gone and the TV is stuck in a boot loop. The backlight comes on, and immediately goes out within 2-3 seconds. No audio jingle, no dimming, nothing.
Here is what I have tried so far:
  1. Disconnect the main board from the power board and power on the TV. The backlight works fine -- > this probably means power board is fine. I even checked the out voltages out to the screen and they seem fine.
  2. When I reconnect the main board and remove either of the LVDS cables and then supply power the same symptom appears - backlight cycles ON and OFF in ~ 10 seconds interval. No boot audio jingle or picture.
  3. If I disconnect both LVDS cables from the main board..still the same issue.
  4. I ordered a replacement main board from eBay. I am sure its the correct model number for the main board (BN94-10828C). I replaced the main board with the one from eBay. Nothing changed i.e. regardless of whether the LVDS is connected or disconnect the backlight continues to cycle.
I'm running out of ideas on what to try and diagnose next. Could the cheapo eBay board also be faulty. I'm perplexed since I've seen in videos online that if the main board is fine then the TV at least boots up and then people try the tape masking process. In my case the TV does not boot up at all.
Link to Video showing the above symptoms
Main Board Images:
Main Board Full:
Bottom Right:
Bottom Left:
Top Right:
Top Left:
LVDS connection:
Power Board:
ScreenPCB Right LVDS:
ScreenPCB Left LVDS:
SMPS to Panel connector:
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
@emmbeeheavy "The backlight works fine -- > this probably means main board is fine" not really. all that means is that your SMPS (power supply) works. From what I read about you pulling the LVDS cables off, that is normal behavior. This is "Two thin vertical lines appeared in the middle of the screen" what is worrisome. WE really need to see all of your boards. Post some good pictures of those with your Question. iFixitでの質問に画像を追加する方法
さんによる
@oldturkey03 Thank you for your response. Yes you are right. When the main board is disconnected and backlight comes on, I meant to say that the power board is fine. (Corrected this typo in the question).
I've added several high resolution images of the main board and SMPS board and screen PCBs and also added a link to a video that shows that symptoms I've described above.
I also suspect there is an issue with the screen due to the original 2 thin vertical lines that had appeared but its puzzling to me that when both LVDS cables are disconnected from the main board the backlight still doest stay ON. Does that mean the main board is telling the SMPS to power cycle the backlights ? Essentially, I do not know how to rule out main board vs screen issue and what to debug next.
さんによる
コメントを追加
2件の回答
最も参考になった回答
@emmbeeheavy the boards look good, but I have trouble identifying the component on one of your LCD driver boards
Can you try to focus and zoom in? You have checked all your voltages on the power supply and found them to be accurate? I am looking for the voltage to the panel. Next pictures we would need are of the LCD boards. The long skinny boards where the LVDS cables terminate on.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Posting the response as an answer below since there is no way to add an image in a comment.
さんによる
コメントを追加
@oldturkey03 Thanks for taking a look at the images of the boards.
I checked the voltages from the SMPS to the panel.
As there are two pairs of wires going out to the panel I measured the voltage to both pairs/halves.
When the main board is disconnected from SMPS and the backlight is ON, both voltages hold steady around 280.5V.
When I connect the main board to the SMPS and measure again, when the LEDs are OFF its around 326V and when the LEDs are ON it drops to about 300V.
I took a lot of close up pictures of the Left and Right LCD boards as well. Since these are long boards, and there are a lot of images I have linked them below.
Upon first glance I did not see any obvious signs of carbon deposit or a component burnt out but then again I am not entirely sure what to look for.
The component you have circled has no readable marking on it.
Left LCD Boards Images
Right LCD Board Images
I really appreciate you taking a look.
What about the voltages between the main board the the SMPS. What should I expect to see there ?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I would expect those voltages for the backlight. What other contacts do you have on that connector? Something related to Panel etc.?
さんによる
There are 4 black wires (2 pairs) going out form the 16 pin CNL802 connector on the SMPS board to an orange 8 pin connector on the panel. I've added a new picture - SMPS to Panel - at the very bottom of the question that shows this connection.
Originally, I thought that the pair of these wires are only for the LED backlights so I assumed one will carry voltage and the other is ground. Also because it is difficult to measure the out voltage on the bottom pins on the CNL802 as they aren't exposed. For the exposed pins the voltages are what I described earlier.
However, after your comment, I was able to measure the voltages on all 4 wires the other side - at the 8 pin orange connecter since there is a tiny exposed metal point where the wire enters the connector where the multimeter can touch.
The voltages on all 4 wires are as follows:
Backlight OFF:
~330V
~190V
~330V
~190V
Backlight ON:
~300V
~150V
~300V
~150V
さんによる
コメントを追加
回答を追加する
emmbeeheavy さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 10
過去 30 日: 34
今までの合計 651
