When I insert memory card it says no memory card detected ,
When I insert memory card inside the memory slot it say no memory card detected,what should I replaced to fix this issue ? A2300 canon
@stanleyfer65323 make sure that you have the right card for your camera and make sure it is correctly inserted. Next I would try to format the card
Now, if you have a proper card for your camera and it is inserted right and formatted but still can't be found, then the issue maybe your cameras card reader. Let us know what you find out.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 7
