Need a replacement power button
My sister has a Asus laptop model G760JM-BSI7N23 it needs a replacement power button. The button does not spring back up. I was able to turn it on. I put it in sleep mode to avoid turning it of completely.
If you can't find a replacement power button by searching for parts using the laptop model number try searching for the power button board part number instead.
I don't know about your G760 model but looking at the Asus G75xxxx series models the power button is on a replaceable board.
For example the part number for an Asus G750 power button board is 69N0QVG10C00-01 whereas the number for an G751 is 60NB06G0-PS1040
Here's a video that shows how to open the G760 laptop.
Check if there's a part number on a sticker on the power button board in the laptop.
If there is, search online for the part number only of the power button board to find suppliers that suit you best.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 27
