Battery for ideapad 330-151GM
I need a battery for the referenced lap top but can't seem to find one for it on your site. Do you have the proper battery for the 330-151GM
Hi @drose25585
Unfortunately, ifixit doesn't have a battery in stock that is compatible with your particular model.
Here's the hardware maintenance manual for the laptop.
Go to p.81 & p.81 Item #12 to view the part numbers (FRU number) for the 8 batteries that are compatible with your particular model.
Search online for the part number only, to find suppliers that suit you best. The battery model number e.g. L16M2PB1, L17M2PB7 etc, is printed on the battery in your laptop should you wish to verify that you're getting the same one (or a compatible one).
Go to p.36 to view the procedure to remove/replace the battery.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 5
今までの合計 29
